I despise having horn start honking for security. Either from hitting the panic button by mistake on key fob or for some unkown reason. I also bought the remote start to be used for heating van first thing in the morning. Remote start is programmed to flash lights and honk the horn before engine starts. Not exactly what you want early in the morning if you are stealth camping or in a campground.
So for a short term (or maybe long term solution) I found the horn and disconnected the connector at the horn. No horn no noise. So far no dash warning lights and engine starts with key and with remote. I will see if Ford dealer can reprogram, but if not horn will remain disconnected. I never use a horn anyway.
