61 - 64 of 64 Posts
With the low cost of electronic parking brakes, I can't understand why manufactures still deal with all the mechanical crap, y cables, adjustments, etc. of a manual parking brake.
It's because they just KNEW I'd be putting a torsen-style rear diff in it and would be needing a handbrake to actuate it :)
Just noting that electronic controlled parking brake still uses mechanical crap, cables, and adjustments.
True, but the entire mechanism can be installed under the vehicle closer to the rear wheels and mostly enclosed and protected, and would eliminate the lengths of cable going to the front, and the entire mechanism inside the vehicle.
Are you guys saying the F-Series still uses cables and the like for parking brake?
I haven’t researched this much at all, but was thinking the parking brake used the standard brakes. I was under impression on these cars (and SUVs and pickups) that you apply brakes and then they are locked closed. Apparently this is not the case?
61 - 64 of 64 Posts
