1 - 11 of 11 Posts
2023 148 high roof long cargo
Are there any van heaters (diesel, gas, propane, etc) that have the option of remote start? Im not needing remote start from anywhere, just similar distance to a car remote start, like from my house out to the driveway. Im aware of some that have timers, but that would not work for my needs.
Cheers.
Wifi not a bad option actually
Im almost wondering if one of the chinese diesel heaters might have remote start? they seem to have a lot of tech on some of them.
There is an after market controller that has that functionality built in -- I think it's called "After Burner" -- by all accounts -- it's quite awesome (full spectrum of heater functionality/adjusting/control and feedback via either Bluetooth or internet/phone if I recall correctly. Check the Chinese Diesel Heater forum on Facebook.
The little remotes that typically come with them (Chinese Diesel Heaters) do not have much range -- although I can get mine to fire up from about 40 feet...but it's hit or miss and tough to tell whether it was successful. Anywhere in the van yes...but outside....maybe.
I have the factory remote start but reprogramed it from 10 minutes to 15 minutes run time. I also installed a vehicle powered pure sine inverter.
I let the van get cold at night and use the remote start before getting out of bed to warm the van. Set the dash controls for max heat and use a selector switch to direct the vehicle powered inverter to power a 750 watt electric baseboard heater.
This system might fill your requirement.
There's a couple threads right now discussing this for an Espar. In theory, it's a relay between red and yellow wires. Which I need to test since mine is also the newer CAN-equipped unit. But if that works, then it's a relay with any trigger you like: over WiFi; or on engine start; or temperature-based; or - in our case - the Victron stuff.
Alternatively is to figure out the CAN setup... then need a bridge for that.
The single-wire ON thing has me wondering about The Afterburner - I really like that setup. I would give Espar the money if they had a LAN-/WiFi-attached controller; unfortunately, they only make one with a 4G chip in it. :rolleyes:
If you want to do the absolute cheapest way with off the shelf parts (more off the shelf than an ESP32 board) something like this should work:
That would be what triggers the non-CAN relay-based Espar to start.
I've got a China-spacher diesel heater so am going the ESP32 route. I'm hoping I can learn the signaling on the wires from the Afterburner community, though the designer mentioned someone started selling knock-off's using his design and code so I may be on my own.
1 - 11 of 11 Posts
