Has anyone seen a graph showing the amperage output from the HD alternator at different rpm's? I want to know what output to expect at idle. Also would be nice to know how much amperage the Transit requires at idle. What I really want to know is how much unused amperage is available to run my vehicle powered 1000 watt inverter at idle. Looking at a Sprinter graph I can see the output increases rapidly up to 1000 rpm and then the rate of increase starts to level off. Transit probably has a similar output curve.
