Just completed a 2000 km trip to an enduro motorcyle race in British Columbia loaded with 5000# trailer and dirt bikes and had a couple minor issues pulling VERY steep grade with the unit. Outside temps were 40 degree C. starting our climb into race site which is about 7.5 km straight up the mountain near Lytton, BC. I have the 350 HD dually with the diesel in it. I have also installed transmission temperature and water temperature gauges just to keep an eye on things while towing. When indicated temps, both tranny and engine got just over 210 F the van completely powered down and wouldn't move. We pulled over to the side, increased RPM and quickly brought the temps below 205 F and were able to get going again. We had to do this at least 10 times getting into the race site. I had TCS locked out and in tow haul mode and tried different combinations but it didn't seem to make any difference. The van just didn't like the combination of high ambient air temps and very steep grade for the 7.5 km climb. Had to run the transmission in first and second gear all the way in. Never boiled over the diesel and I checked the tranny fluid once we got to the site and it seemed perfect. This is likely the hardest thing my van will ever have to do. I would have liked it more if it didn't go into this "preservation mode" but I guess if you didn't have the gauges you would never know exactly what the temps were doing. There was no indication that came up on the information display and the factory engine temp gauge never moved from the half way mark where it usually sits even though the engine according to my aftermarket gauge indicated nearly 215 F at one point. I might get the tranny oil annalyzed just to see what they say and if I do I will post results but it didn't smell and appearance was fine.
