I have been using an EB 150 for several years and could not be happier. Their support was difficult at first but then seemed to get better.
I briefly considered a power station to replace my lead acid battery-based system. It's surprising the AC200Max is one of only a few stations that has more than a 10A 12VDC output. A van conversion seems like an ideal use case for these units, 10A is about half the bare minimum.The AC200Max's 12v/30Amp RV Port helps with this and isn't talked about enough when comparing to Ecoflow/Jackery units. I understand the Goal Zero units had a max current cable available to gain a higher ampage output.
Completely agree - I can't believe Ecoflow and Jackery keep updating their units but seem to miss this key feature. This and a wired display/controller would be great.A van conversion seems like an ideal use case for these units, 10A is about half the bare minimum.
What’s the charge enhancer ?I ordered the charge enhancer too. Another difference with solar charge. I think it’s as good as all rest. Love the expansion ability too!
It has been $1500 before i think on black friday once, so the current price of $1600 isnt terrible.I’ve been eyeing up the ac200max to replace my jackery 1000. This sale price pops up from time to time. Wonder if it gets a little better around the holidays
I have a AC200Max and live in Maine. A few times this winter I wanted to charge it up to 100% before going off for a weekend and it wouldn't charge because it was too cold. I had to bring it inside my house. I've since added a 12V cable hooked to the CCP. More info in my other reply to this thread.Been looking at Bluetti, Anker and other mfg.
Noted that AC200Max is spec'ed to operate at -4 to 104 F; much better than other supplier(the exception is Eco Flow ?).
Can someone confirm that there is a built in BMS that will protect the battery if temperature dip below the operating/storage temp specs. ?
Somewhat surprised to see this new specs; it seems, just a few months ago, the temperature specs. was much higher; so was considering using Victron Smart Battery setup etc...
Agree! I did try to look for one online but didn't have any luck. If anyone has found one, please let us all know!I really wish they made a 90 degree plug
I purchased mine on November 13, 2022, and there was some sort of sale on at the time so I paid CAD$2,199.00 down from CAD$2,599.00 which works out to be ~15% off if wanting to compare to USD. I was in a rush to purchase to get my heater going so was happy not to be paying full price (if anyone ever does these days?).I’ve been eyeing up the ac200max to replace my jackery 1000. This sale price pops up from time to time. Wonder if it gets a little better around the holidays
the low temps was one of the deciding factors as well as I live in the frozen tundra. IM 99% sure it has a built in BMS.Been looking at Bluetti, Anker and other mfg.
This is real world use I love to hear! So you are running a fridge, fan, and heater (presumable heater and fan not at same time) with the bluetti 200max and still only uses 20% of battery overnight, and they you are easily able to recharge it to 100% with a 95W cigarette lighter and no other charging source? Love it!!I know you already bought one but....... I bought an AC200Max about a year ago. My van is a very simple build with Maxair, 12V fridge and a Webasto heater. I picked the AC200Max because of the RV plug. As others have mentioned nobody else except GZ offers a higher amperage port. I feel the Bluetti is a much better unit because of the battery chemestry so that's why I went with it. I took the RV plug that's included with the unit and cutoff the end and wired that to a blue sea fuse panel so I didn't have to buy any additional cables. The one thing that sucks is the plug sticks out a lot. I really wish they made a 90 degree plug, I'd be willing to buy that. We use our van for weekend adventures so we rarely are in it more than 2 nights. That being said I could get an entire weekend out of it if I was conservative with the usage like running the fan only when sleeping and getting the fridge cold by plugging it in before filling it up for the weekend. It worked but I was always nervous I'd run out of power. So I bought a heavy gage cigarette wire off amazon (link below) and hooked it up to the CCP on the port that only supplies power when the van battery is healthy. (I have dual batteries) I ran this wire to the back of the van and use the supplied cigarette lighter plug from Bluetti for charging. It will only charge at about 95W but I've found since we drive around so much it gets to 100% quickly and only drops to about 80% with the fridge and heater running all night. If we drive even a little bit the next it's back up around 100% because it'll keep charging for a bit even after you turn the van off. This solution cost me about $20. I was going to do a DC converter and the charger as others have mentioned but I have no need to charge that fast and it was expensive. I also bought a 100W foldable solar panel for if we plan on being in one location for very long but honestly have never needed it.
I did have one issue where the AC power brick died on me. I kept trying to call and leave messages and nobody would ever answer or call back, I was getting really frustrated. In the end I emailed them and got a response the next day. They sent me out a replacement brick and I had it in a couple days. Point is if you need customer support just email them. I always prefer to call but most companies are going away from that.
Link to 12V port.
Amazon.com: 12V/24V Fixed Thread Cigarette Lighter Socket Extension Cable with Perforated Terminal, Direct Battery Type, car Cigarette Lighter Adapter. 14AWG 20A Heavy Duty Cable 10FT(Free Two Blade fuses) : Automotive
Buy 12V/24V Fixed Thread Cigarette Lighter Socket Extension Cable with Perforated Terminal, Direct Battery Type, car Cigarette Lighter Adapter. 14AWG 20A Heavy Duty Cable 10FT(Free Two Blade fuses): Cigarette Lighters & Parts - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
