I have been considering using Coroplast plastic sheet
for some interior construction parts in van -
Coroplast main advantages are-
Light weight -
Several thicknesses and Strengths available -
Easy to cut and form -
Easy to clean -
Flexible -
Very low water absorption-wont rot -
Many Colors-
Fairly Cheap -
Local availability -
But--->
Gluing (bonding ) many plastics can be very hard to to do-
Bond is weak because of Low Surface Energy of the plastic-( LSE )
Plastics like Coroplast have LSE and are hard to bond to
itself or other LSE materials -
Apparently spraying Coroplast or other LOW Energy Surfaces
plastics with a thin coat of
Krylon Fusion® Spray Paint for Plastics
will Increase the Surface Energy and will enable adhesives
like 3M VHB/HB tape to be used
and provide much stronger bond -
Treating LSE plastics with Krylon Fusion before bonding
Supposedly can provide a Lap Joint in Coroplast that are
very strong and Lasting when using VHB/HB tape -
I also read the info below Online and have not tested so
I really have no clue if it works ----
Another technique to Increase LSE on Coroplast is to slightly heat
the surface area of the Coroplast with a propane torch -
(Dont melt plastic just brush flame over plastic )
This increases LSE to Higher Surface Energy state and
adhesives like CA adhesives (Super Glue) can be
used to bond Coroplast -
(Very Thin coating of CA REQUIRED )
When done properly Increasing Surface Energy treatment
a drop of water will spread out and not bead up as is
normal on untreated Coroplast -
Coroplast is used in outdoor signs like For Sale signs etc -
To get the screen print paint to stick to the Coroplast
the plastic is treated by a Coronal Discharge -
this process Increases the Surface
Energy and allows paint screen printed to stick -
(Coroplast not treated with Coronal Discharge screen
print paint easily peels off --water beads up )
I think Coronal Discharge is similar to the process
used in copier machine but not sure -
have Not tried Either of the the above treatments so I
really dont know if it will work well OR at all -
just figured would pass info it on
To find out more info Wiki Low Surface Energy -
3M site also explains Low Surface Energy well -
Light weight -
Easy to clean -
Flexible -
Many Colors-
Fairly Cheap -
But--->
