Glued Vinyl Flooring
1578 Views 3 Replies 3 Participants Last post by  asdrew
On 2021 R2X HR 250 Cargo, there is an option for front and rear vinyl flooring. Is the rear glued down in a way that it could not be easily removed? Thanks in advance.
1 - 4 of 4 Posts
If it’s like the crew van then it is just vinyl on an insulated board of some kind that’s loose laid in the van. No glue or adhesive of any kind.
Thanks for reply and info. When I asked my salesman he indicated it was glued down all over. I'm going back thru different channels at dealership now to see if I can get better info.
I really would like this option initially as I think my van will be coming too late this summer for me to get to my floor. Would like the protection, sound deadening, and smooth surface for my dogs until the real deal is it. Also very interested in using this for a template at some point to cut out my plywood sub floor, and then later to protect the new floor should I be hauling....whatever.
Reactions: 1
Your salesman would have been better off answering I don't know rather than showing his ignorance by making up an incorrect answer. This is probably a good indication of other "answers" he may provide.
Floor coverings are not typically glued to the floor itself in most vehicles.
Pulling out the factory flooring and using it for a template is quite convenient and often done.
1 - 4 of 4 Posts
