1 - 20 of 30 Posts
Hello, I have a 2015 Transit 250 with ecoboost. I only have 1800 miles on it but lately I have been noticing a strange smell in cab and it's giving me a head ache! I don't know it its just the new engine or if it is exhaust fumes. Any of you had this issue?
Thanks
My helper used a 50cc leaf blower inside the van and the fumes lasted 2 or 3 days but it's mostly gone now. My shelving wood has a smell but it's pleasant.
Point is there's no outlet for air so maybe drive with Windows down and rear door open to air it out.
Could have gotten fumes from a Stinky car ahead of you (through vent) and no way to get it out.
LOL... No I am serious. I just drove from Winter Park to Denver in a blizzard and had to keep passenger window down half way.
Blizzard? That explains it. Lactose intolerance. DQ stuff is murder. Seriously though, you might be sensitive to one of the volatiles outgassing in the interior, have a serious malfunction involving a fuel or exhaust leak, or perhaps you collected a plastic bag or similar with your exhaust. Has anyone else experienced this in your van? Do you have access to a canary?
No passengers so no other complaints. I did have a bin package installed (Bulkhead and shelves) and drilling into floor in several locations was done. I guess it's possible they could have hit a line or something. I'll get under van and check it out.
Battery powered carbon monoxide detectors are pretty inexpensive now- might pick one up to find out if it is exhaust.
I've set the one off in our travel trailer by running a generator nearby with the windows open- I'm really sensitive to fumes and it can be so weak I don't smell it but the detector does.
I just ordered a combo smoke/CO detector for my van- since I plan to sleep in it I want to be sure a bad heater or something overheating doesn't kill me-
Notice it is $31 if you order one EACH. If you order one PACK it is $26. I think the difference is the box it comes in....strange.
Reactions: Zymurgy
I notice an odor every time I accelerate heavily. Not a normal exhaust odor. I drive mostly with the windows down. The odor is not coming from the tail pipe. Now at 2500 miles and have always had the issue.
I have fumes... but it's from the dirt bike that is in the back. Seriously, I need to come up with a way to vent the whole van out some rear exit. On my list of many things I would like to get done. :)
Same here. Thinking of venting rear door. I don't want to add a vent to the roof as it would end up snagging everything I'm sure. Mowers and blowers and atvs stink up and the fumes stick to the walls and seats especially from a two-stroke.
re: kingkabong -- Same here. Thinking of venting rear door. I don't want to add a vent to the roof as it would end up snagging everything I'm sure. Mowers and blowers and atvs stink up and the fumes stick to the walls and seats especially from a two-stroke.
You two might think about venting out the bottom of the rear pillars. One of the members here made an air plenum above the doors, with fans, and ran flex duct down through the pillars, and out the approx. 3 1/3 x 5 inch holes under the van (they come with large, flat plugs). One issue to watch for if you use the right side, is proximity to the exhaust outlet. You also have to figure out a way to close everything off, when fan function is not needed.
Discussion Starter · #14 ·
http://www.amazon.com/gp/product/B00PC5S0PA?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00
OK, I found one 1/2 inch hole that was drilled in floor for bin package that was not used. It was on driver side near the very back. I didn't think that sealing it with silicone would fix the fumes issue but it did!! The interior of van must act like a vacuume and was sucking in some of the exhaust. I wonder why FORD stopped the exhaust pipe way short of the rear of Van? Anyway I'm going to seal all the drill type nuts that were put in. At least the ones I can access from under the van.
That has concerned me as well- wasn't sure if all Transits were that way or just the extended length ones.
My Sprinter was the same way, when I had the exhaust replaced the shop rerouted the pipe straight out the side, but honestly had no fumes in the cabin.
Glad you found your problem and it was an easy fix.
I like the idea of throwing a carbon monoxide detector to check the integrity of the exhaust. My sister complained of fumes in the back seat of my '66 300. I am just looking for an excuse to add dual exhaust. :)
I did notice a smell at one point after moderate acceleration. It was not combustion fumes as i know them. Could it be a product of the extreme temperatures produced by the twin turbos?
I also noticed a lot of cool air draughts on my hands when I was working on my electrics behind the drivers seat. The air seemed to come from the punched holes in the lower B pillar frame.
I am thinking lots of air is finding its way in through van cavities,and bringing in whatever with it.
My thought to mitigate this would be to create a natural convection exit, as high as possible, so air passes outup high.
Or open a window.
Discussion Starter · #19 ·
Or open a window.
I'm going to pick up a carbon monoxide detector today and install it. I'm going to try it in a few different places to make sure all is safe. If one half inch hole was letting in the fumes that was making me sick then I'm checking into this further.
1 - 20 of 30 Posts
