Project: to install roof rack mounted LED Light Bar for off road use.
Interested in opinions on attached wiring diagram to control the LED Light Bar when the engine is on.
1. Turn LED Light Bar ON regardless of vehicle lights being on or off
2. LED Light Bar comes on ONLY when High Beams are ON.
Two Switch solution – Use Upfitter Switch to energize LED Light Bar. Use Mini Rocker (SPDT) to control the LED Light Bar.
Will wiring diagram accomplish my goals ? Any suggestions or opinions ? Do you see problems with this ?
Attachment PDF contains information in screen shots
FYI - All three Customer Connections Points are hooked up and protected with 60 amp fuse.
Thanks
Jim
Thanks
Jim
