1 - 17 of 17 Posts
cool. i'm planning ot put a half inch plywood floor down covered with 3/16" rubber mat. The way these mount would there be clearance for that? If so, how much to ship to Indiana?
2020 Transit 350 AWD van long, medium roof
Discussion Starter #5
I believe they will clear a 3/16" rubber mat, but I doubt they would clear another 1/2" plywood. You would need to put spacers in or trim the plywood to make it fit. I'd guess ground shipping/packing would take about 5 days and cost ~$100 via UPS from WA to IN. The steps aren't heavy, just bulky.
Discussion Starter #9
they're a little less than 3/8" tall, other than the right hand tubes which areabout 3/4" tall... see these pics (First two are from the right rear step, last one is from the rear)
yeah, might not work then. i was concerned with my rubber mat getting torn at the edges. i'm sure i can find some type of flooring trim to fix that with.
Discussion Starter #11
it's designed to cover the ford oem rubber mat so the ends don't fray. Anything sitting on top of the rubber mat will need to be trimmed.
mine doesn't have the mat so i was going to make a floor out of plywood then cover it with a mat. i'm open to other ideas though. main use of van will be hauling dirt bike and mountain bikes.
just found this, it might work out better, probably wouldn't need plywood with this, or might just need some strips in the ribs if anything. plus wouldn't be giving up as much floor height. i'm 6'4" and have the medium roof.
Discussion Starter #14
Here is what the ford oem rubber mat looks like. it's flat, but nonslip
1 - 17 of 17 Posts
