Motivated Seller! Lets make a deal!
All Victron Electrical Components
300Ahr battery, 3,000w inverter, (3)175w solar panels, 30amp shore charging plug
RV queen size bed, measures 60” x 74”.
Oversized 3.2cuft standup fridge
Full size indoor shower
Front swivel seats
25 gallon fresh water tank
20 gallon grey tank
4 gallon hot water heater
Van Specs:
148” Wheelbase, High Roof, Extended Length
3.5L EcoBoost V6 (gas)
10-Speed Transmission
3.73 Non-Limited Slip Axel
9,500lb GVWR
Exterior – Oxford White
Interior – Dark Palazzo Gray Cloth
Exterior:
Auxiliary Fuel Port
Rear Door – 180 degree swing-out
Rain Sensing Wipers
Interior:
Center Console w/storage
12V PowerPoint and USB (front)
Steering – Tile / Telescopic
Radio – Sync3, 8” screen
Cruise Control
Single 70amp-HR battery
2 additional keys (4 total)
Vinyl Front Floor Covering
Factory warranty:
3yr / 36,000 Bumper/Bumper
5yr / 60,000 Powertrain
5yr / 60,000 Roadside Assist
Camper Specs:
1,000+ pictures are available for reference of the build process.
Electrical:
Victron Lithium Battery – 300ah
Victron MultiPlus-II 12/3000/120-50 2,120V Interter Charger
Victron Smart Solar MPPT 100/50 Charge Controller
Victron BMS Smart Battery Management System CL 12-100
Victron Smart Battery Protect w/Bluetooth
Victron Smart Shunt 500a
Victron mk3-usb interface
BEP 770-EZ Pro 400A On/Off Switch
Blue Sea Breakers – 150A (alternator), 100A (DC Fuse Block) & 50A (Solar)
Blue Sea Heavy Duty Bus Bars
Blue Sea Class-T Fuses 350Amp
Blue Sea 12v fused DC distribution block
30amp Exterior Shore plug
(3) Renogy Solar Panels, 12V, 175W
All Ancor Marine Grade Wire
Plumbing:
Norcold N1090BR Refrigerator
Thetford Porta Potti 365, 5.5-gal flushable Cassette Toilet
Gravena Undermount 16”x18” SS sink
Sarai SS 1 handle Pull-Down Faucet
Dometic D21-SEC / 50216 RV – 2-Burner Propane Cooktop OR a 2-burner induction cooktop.
Bosch 4-Gal Water Heater
25-Gal Fresh Water Tank
20-Gal Grey Water Tank (Undermount)
Shurflo 4008 Water Pump w/Accumulator Tank
Water Filtration system – Sediment & Carbon Filters
Passenger side exterior lockable water fill
Propex tubing with Uponor Fittings
Brass Ball valves
Garden Hose connection at grey water dump and fresh tank drain
