1 - 4 of 4 Posts
Our Ford Transit cargo van (long, not extended length) came without any flooring. We're putting down a plywood floor and would like to buy the plastic sill and scuff plates that come with the factory floor mat.
In the first photo below, the parts shown in green are what we're looking for. The next two photos are of someone else's van, showing the side and rear plastic plates with the factory floor mat.
If you've removed or replaced yours with something else, let's talk. We're in San Diego and will pick up the parts or pay for shipping.
Thank you, Terri
If you've checked with Ford you've found that these items are pretty pricey. The fastener cost is outrageous. Clearances are designed for the vinyl mat so you'll have to butt the plywood. Holes need to be drilled for the side piece.
Yes, I did check with Ford and thought they wanted too much. Sounds like you also considered buying them. What did you end up using instead?
1 - 4 of 4 Posts
