21 - 29 of 29 Posts
I can see the key codes, but none of mine say anything about the trailer brake controller...they all say not configured. Any ideas?
130458
Finally figured it out today. Uninstalled the newest version of forscan and tried an older version and boom was right at the bottom. Everything works as it should now! So for anyone attempting this mod don’t use the newest version!
Interesting. It seems someone else had a similar version issue a few months ago, glad you found the solution! #persistencepaysagain
Note to self: keep installation files for several FORScan builds on hand. :geek:
So I bought a 2017 Transit at the beginning of the year that didn't have a feature I really wanted, the factory trailer brake controller. The dealer told me it could be added after the fact. Well the mechanic at the dealer pointed out after I bought my van that this would not be possible as the factory wiring was not there. Not wanting to sell the van I just bought with a nice discount, I took it as a challenge and did just that. >:D
My van does have the factory trailer wiring provisions, but the connector for the trailer brake controller was nowhere to be found. I attached a tone tracer to the trailer brake wire at the 7 pin connector and found that the signal ended under the hood. The mating connector was not pinned and trailer brake controller wiring was simply not part of the harness. After much studying of the Motorcraft Service data I took the dash almost entirely apart in order to gain access to the bulkhead grommet, fuse box and a convenient place to splice into the HS CAN bus. After some serious googling I sourced the necessary connectors, harness tape, fuses, wire etc for a near factory install, got it all wired up and not surprisingly it only lit up the lights but did not work.
What I did to fix this was purchase an OBDLink Mx bluetooth adapter to work with my laptop and downloaded FORScan. I couldn't find much info on programming it since most of the US stuff is programmed with the As built data. For a Ford F-150 for example, you find a VIN that has the features you want to enable, download the As built data through Motorcraft and do a comparison between vehicles. You can then find the difference in the module of interest (radio for example) and flip the bits around by changing the hex value and you can turn that feature on off, which may or may not work depending on what you're tying to do. Well that method was not successful for me, but what did work was to edit the "central configuration" which is how the Euro Fords are configured. What's great about central config is it's all in plain english, you don't have to spend hours with trial and error figuring out what a single bit does. I was able to enable the rear window defrost switch through the central config as well.
For the most part setting up the OBDlink and installing Forscan is pretty easy.A license for Forscan is required to get into engineering mode to make the changes to central config. The only "tricky" part was making sure FORScan had the calibration files. It's looking for them in C:\Users\your-username\Documents\CalibrationFiles. The files are *.vbf and can be downloaded from
fordtechservice.dealerconnection.com/vdirs/wds/PCMReprogram/DSFM_PCMReprogram.asp?swproduct=IDS , but I ended up finding a folder of them on the Forscan website.
After programming the brake controller not only worked, but the gain is displayed on the instrument cluster just as it's supposed to be. I did a test pull with my trailer and the gain settings work as intended and the backup sensors were disabled as they should be. After that success I ordered the parts needed to complete the install into the center console. I ordered the trim bezel, cup holder, cup holder rubber insert and coin tray insert for the right side of the bezel from Tasca parts. The center console had the holes for the retainer clips welded in, all I had to do was carefully cut the skin to fit the bezel.
In conclusion, unless you're hellbent on an OEM brake controller and OK with assuming personal liability for your vehicle modifications, I suggest going aftermarket, however it is entirely possible to get the factory trailer brake controller fully functioning without having to buy more than the factory brake controller, OBD link and a Motorcraft Service data short term subscription as long as your van has the harness. With all the trouble this was I hope someone finds it useful. If you have some questions I'd be glad to answer them. I didn't document everything but I have saved part numbers for building and splicing the harness.
would you like to pin point exactly where you got the files on Forscan ?????
21 - 29 of 29 Posts
