While pulling my van into my garage I've noticed what I would consider an excessive amount of water coming out of the A/C condensate drain, at least I think that is where it's coming from as I couldn't actually locate the drain line. My research revealed that it's above the transmission, which makes sense because it was running down and dripping off the back edge of the transmission pan. When I say excessive I mean a steady stream, not dripping. After about 5 minutes of idling there was a probably 2' diameter puddle on the floor. Temp outside was about 90 and pretty humid so I know it was pulling a lot of moisture out of the air but I've never seen what looked like a faucet running under the van. Is this normal and what should I check if not? There is no cabin air filter installed and I know very little about A/C systems. The A/C was blowing cold and seemed to be fine other than the lake forming underneath.
