Do Air Coolers require a lot of electricity to run?
They are just fan blowers so, not much power needed but they only work in very dry areas and are useless in humid ones.Do Air Coolers require a lot of electricity to run?
Understood, but how long can it run with just the water in the sump?the water is stored in a sump at the bottom of the swamp cooler, an electric pump circulates the water through a medium, air blows through the medium and produces cool moist air, excess water drains back to the sump. the sump has to be often refilled unless it is plumbed into the household water supply with a float valve in the sump.
Air coolers are much more economical than conventional air conditioners (about 10 times) and consume a little more electricity than a conventional incandescent light bulb - 70-150 W.Do Air Coolers require a lot of electricity to run?
