I got an update from Espar support:
After the phone call, I felt that nothing good was coming of this troubleshooting effort....just despair.
Since the phone call, the heater ran for about 90 minutes for first time ever and then shut itself down. What's different? It is freaking cold out (15°F). The gas in the gas tank is very cold and the heater exhaust pipe is dissipating heat quickly.
Watching the fuel line while the heater is running, I still see about the same amount & size of air bubbles after the fuel metering pump on this cold day compared to warmer days.
I've run several more tests and they are all running far longer than when I've tested in warm weather, but all still fail eventually in the same way (P000129).
Next I ran with a leaf blower pointed at the bottom of the van where the heater is. This was successful for 3 hours until I removed the leaf blower and then the heater shut down again in about 10-15 minutes. I think I can now conclude that the issue is heat buildup below the heater affecting the fuel in the fuel line or the pump.
I took temperature readings shortly after removing the leaf blower while the heater was still running.
Basically, the fuel line quickly heats from 60 to 100 to 180 in about the last 3 inches approaching the heater.
I had split loom on the fuel line, it is currently off from all the fuel testing I've been doing. The behavior was no different with the split loom in place.
Questions for anyone still reading:
- what is unique about my install that no one else seems to be experiencing this?
- how best to protect the fuel line from the heat?
- how best to contain the heat in the first few inches of the exhaust?
Thanks for following my painful, circuitous journey, hopefully I'm getting close to getting this resolved.
- the latest Espar Repair Instructions doc is attached, the one I posted earlier was obsolete.
- I'm back to my original support guy, he insisted the sensors are not the problem and would not address the fact that I could not get valid readings.
- He insisted that I use a non-lithium battery as the power source, even though I have a voltage regulator providing 12.44 volts to the heater. He said they have problems with lithium batteries and they don't know why. So they won't support systems with lithium batteries.
- He wants me to compare the performance using kerosene as the fuel since there won't be bubbles after the fuel metering pump with kerosene. He wants the fuel quantity test and a 30 minute run test with both fuels.
- he is convinced that there is nothing wrong with the heater and the problem is in the fuel delivery. He offered that there could be a heat source causing the fuel in the line to heat up causing a problem like the van's exhaust system or a large wiring harness.
