I'm game for a chat-session if others are. I've enjoyed meeting a few of the folks here - even got some skiing and biking time with a couple.
I feel like I'm answering these questions in an odd manner... but see if the overall input makes sense...
We have a
Giandel 2200W inverter on the DC-AC-DC side. Nothing fancy about that, as far as I know. No transfer switch on the Giandel, obviously. And we didn't install a transfer-switch for the above reasons. But now that I think about it, though... I think there's a chassis-ground for the Giandel that I never connected - assuming it was already covered by the ground side of the Giandel unit. But I bet it's not since the docs say that the AC neutral is not bonded to ground and they recommend attaching the chassis ground to earth. I have not connected it. Hm... interesting one.
The Giandel inverter is on the far right in the photo.
That unit feeds a single "AC out" that is non-GFCI. I think that was an early-testing thing that I completely forgot about until just now - probably should be a GFCI there, right? That outlet is typically plugged into the "shore power in" plug just to the right of it with a 1' cord.
That "shore power in" (obviously inside the van) feeds the
Multiplus 24/3000/70 unit and is seen as "shore power" when in DC-AC-DC mode. When actually connected to shore-power, we run an extension cord through the window and plug it into that plug. We do it very rarely, so it works fine for us. But when we do it's almost always from our house with a dedicated GFCI straight off the main panel - seemed the right thing to do since I'll push that thing as far as 20A when I'm using it (as above, it's a 20A GFCI). Makes me wonder, though... should I have a GFCI or ELCI between that shore-power input and the Multiplus? 🤔
The Multiplus has a built-in transfer switch and the ability to pass through the shore-power ground or not (as well as combining shore plus inverter for extra power and/or UPS functions). I typically leave the ground pass through feature turned on as it seems like the right thing to do when on shore-power... but I'm unsure if that's a bad thing when in DC-AC-DC mode, since the Giandel is likely isolated - though I'm not sure about that. This is one thing I'm unsure of: might be better to NOT pass it through and rely on the chassis-ground path since that is more commonly in use? 🤔
The output side of the Multiplus goes into two GFCIs - one on each side of the van that feeds outlets and loads. Each of the two GFCIs has additional outlets strung off the back of them.
Interesting thing: at one point, someone dumped a bunch of dishsoap down the back of the galley and swamped an outlet back there - when I initially only had the one GFCI shown above with everything off the back of it. It popped the GFCI. And, of course, it was not just going to "reset" until that outlet was removed from service. That's when I broke it into two sets of GFCIs - so the whole system wouldn't be down for one such mistake. Initially, I installed a GFCI in place of the ruined outlets and that did NOT work. Duh. Can't string GFCIs in series. Things I don't think about... 😬
Let's see... yes, the house DC system shares a ground to the chassis; but it's a fairly small wire (#4, IIRC) relative to the possibility of the Multiplus trying to find it's way back there. I based it on the likely load paths, not on the worst-case failure path. And I still don't really understand all the implications thereof.
On the transfer switch thing... my brother recently set up almost the same config and hadn't installed his ATS when he plugged into shore power and forgot to unplug the Giandel he's using... fried that thing.
Okay... educate me! And thank you! 🙏
