Great input. Thanks.
Open to any more comments or suggestions. Right now, I like the DC side of my system as is, provided that the BMS short circuit protection can be considered reliable. Otherwise, a change is in order.
Also, I will probably follow the suggestion to increase the DC load capacity, even though I don't need it.
Still one area that I would like to continue to discuss, revolving around the suggestion from @cycle61 that I consider "an ELCI on the shore power inlet."
Right now, my plan for shore power is to use the following components:
1) 30 amp Smart Plug cable and socket
2) Blue Sea 8077 AC Main Panel
into Magnum 2812
out of Magnum 2812
3) Blue Sea 8099 Power Distribution Panel (30 amp main double pole breaker, 4 15 amp breakers)
4) Four GFCI duplex outlets (one for each breaker)
Specifically with regards to ELCI most of the info I have seen discusses ELCI protection at the "dock" (in our case either home or campground power) rather than on the "boat" (in our case the van, or camper). What part would I use on the camper and where would that part be placed?
Generally, any comments on the shore power portion of my system would be appreciated.
into Magnum 2812
out of Magnum 2812
