1 - 16 of 16 Posts
I installed an engine cover on my 2019 T250 with 3.5L ecoboost. It fit pretty easy. Only minor trimming on the rear driver side was required to clear the brake booster and vacuum line. I also had to trim passenger side but only because I have an aftermarket oil separator installed and I needed to clear the hoses. I did NOT use the forward mount for the engine cover, it is very secure without it.
I did remove the fuel pump silencer by the brake booster for the cover to fit.
If you want to get the parts at a junkyard, look for a 2013 Ford F-150. You will need the cover, the rear bracket with it's three M6x1.0 bolts and the oil fill cap extension.
If you want to go brand new, Ford part numbers are as follows:
Engine cover - DL3Z-6A949-D
Rear bracket - BL3Z-6N081-B
Oil fill extension - BL3Z-6763-B
Insulator mount - AA5Z-9P686-A
Picture without cover showing rear bracket installed and the oil fill extension installed. I added spiral wrap on vacuum line near rear bracket to prevent chaffing.
131857
131858
Beauty. So TURD-like, yet, it is the un-TURD.
Sick, did you find your parts used or did you order new? Looks good. The oil fill extension is useful no matter what.
Discussion Starter #8
I could see how that could make it easier to sale if you ever wanted to sale it , clean/detail engine ,, paint the engine cover , take picture of engine bay and post with the rest of the pictures. Sold
THAT will keep some of the water and dirt out of the bolt wells! I might need to do this, too.
I thought this one was cool. Think it was $300 though so a little rich for me
132687
1 - 16 of 16 Posts
