Check your turbos for coolant leaks.Reviving an old thread, I have noticed this smell as well, coolant level is at minimum now with 25,000 miles (no way to know if it was ever topped off at scheduled maintenance). I have noticed it after a very short drive as well as at the end of a steep hill climb. It doesn't happen every time I drive.
Sent from my SM-G955U using Tapatalk
I test drove brand new vans at local dealer and most of them were low on coolant.Reviving an old thread, I have noticed this smell as well, coolant level is at minimum now with 25,000 miles (no way to know if it was ever topped off at scheduled maintenance). I have noticed it after a very short drive as well as at the end of a steep hill climb. It doesn't happen every time I drive.
If I remember, (no, I didn't go check) there are two marks. One is for "Cold" level and one is for "Hot" level.After reading this thread I checked my coolant level. Sure enough, at the minimum mark with 27,000 miles on my 2015 with Ecoboost.
I do remember a slight smell of coolant a couple times in the last year.
This might be a good forum thread to check out, Coolant reservoir leaks are a common problem. The plastic ages from the heat and cracks.Thanks for the info!
I sure hope it's something like a tank leak or hose. I took a chance and bought it even though it is a displacement (1.5L) thats claimed to have issues with engine sealing. Thanks and I will let 'you all' know how it goes.This might be a good forum thread to check out, Coolant reservoir leaks are a common problem. The plastic ages from the heat and cracks.
Coolant smell no leak
Hi everyone. I was hoping I could get some advice on what to do. I have a 2016 t250 ecoboost. I started noticing a sweet burning smell a few weeks back. When I popped the hood i noticed the coolant reservoir was low. I topped it off and brought it to the mechanic. He pressure tested it and...www.fordtransitusaforum.com
So a Transit Connect? Most of the folks here have the Big Transits, so good to specify if it is a Connect, lest you get some confusing info. You can always put your vehicle info into the signature in your account info and it will show on the bottom of all your post. FWIW - there is a Connect section on this site and I think there are also somes specific forums specifically for the connect. Maybe someone will jump in and post those links.displacement (1.5L)
Yep, We have a section in this forum for Transit Connect owners, You should probably ask your questions in that section.This might be a good forum thread to check out, Coolant reservoir leaks are a common problem. The plastic ages from the heat and cracks.
