1 - 2 of 2 Posts
Posting some pictures of what I did with the e-brake shroud. It was hard to find info on any solution that made it retain it's stock appearance (and pardon the messy van, I've been fishing a lot and it was either clean the van or install swivels, so I installed swivels). So I figured I'd make a thread just for shrouds so you don't have to sift through any other info since most seat swivels are a super simple install.
136466
So that was the finished shroud up above. I cut my shroud from the bottom. It took some fine tuning still to match the height up correctly but I think I ultimately ended up with about a 1-1/2 to 2" trim from the bottom. This is how I started the trim:
136467
1" at first, all around, the slanted angles need more or less trimming depending which way (forward or rearward) they are going so trim those last after you figure out your height
136468
I trimmed these tabs off with an inch of extra plastic to be riveted back to the inside so I could reattach the shroud and not have it rattle around. Someone said they didn't do this and the shroud sat well, but I didn't want it to bounce off with the trails I drive.
136469
Clean them up like this (above) after cutting them off then attach them like this (below)
136470
In the photo above, you can see that offset after getting riveted, the bracket I used is 1/4" thick and this helped stop the shroud from rubbing after that bracket by adding about 1/8" of offset to compensate for that thick relocation bracket.
The lower shroud also needs to get trimmed on the inside too to lower the e brake. You can sort of see it here (below)
136471
136472
So that's what I did with the e-brake shroud. I think it came out pretty good. It took time but there was constant adjusting and trimming to dial it in better. Go slow, and it can be done though.
1 - 2 of 2 Posts
