2022 ordered 2/7/22 - balanced out. 2023 ordered 7/11/22. MR, AWD, EB, Avalanche Grey, Digital RVM
Does anyone know if the Ford dual alternator option affects MPG?
I agree with @carringb above statement.The fact that there’s two alternators shouldn’t have any measurable affect.
Is that from the display or actual calculated by miles driven and refueling gallons?I have the dual alternators, and I have consistently among the best mpg of anyone that I see post on the forum (148 AWD non ext. With Ecoboost, I get 17-19 mpg driving mostly highway in FL)
I just discovered this a few weeks ago. If you have the instantaneous mpg reading selected to show on the dash, it changes to gph at idle or when barely rolling along.
Thanks for the numbers. Even if they are estimates, it's still something, and it's helpful to me for a thought experiment I'm attempting.I agree with @carringb above statement.
For whatever it is worth, with regards to actually producing electricity:
240 amps @ 12 volts = 2880 watts
2880 watts = 3.9 horsepower
Modern engines use about 0.38 pounds of fuel per horsepower per hour.
So, theoretically, that's about a quarter of a gallon of gas to make 2880 watts for one hour. Not exact, but should be close.
Certain amount of irony in any of us seeking a 1/2-gallon savings while driving four-ton rolling houses... 😏...
So I'd save 0.4 MPG, or 1/2 gallon, or ~$2. Hmm, not as big a savings as I might have hoped for. Bummer...
I am going to use two of my "upfitter switches" for these functions. One to turn the charger off/on, and the other to switch between "100%" and "60%" charge targets.FTR, I target sub-100% SOC by enabling/disabling charging as you suggest. I could do it programmatically (easy enough with NodeRED built in to the system); but I just tap the "button" on my mobile phone to change rate or turn off OR shut off the alternator-attached inverter itself. I do that for battery life, not for fuel savings.
Certain amount of irony in any of us seeking a 1/2-gallon savings while driving $$$ four-ton rolling houses... 😏Certain amount of irony in any of us seeking a 1/2-gallon savings while driving four-ton rolling houses... 😏
Agreed, although this can just as easily be done with the standard DC-DC setup. By supplying a control switch to the Orions they can be controlled either way (switch or app). Personally, I'd much rather just have a dash switch. I don't want to be messing with my phone while I'm driving.WRT your on/off idea and considering the possible variable output / charging from alternator: you've probably already looked at the DC-AC-DC setup; but if you haven't looked at it yet, it allows you to enable/disable charging from the alternator and set it anywhere from ~75A (alternator) draw up to the limit of your Multiplus you've got planned.
Same as above, the switches don't disallow the use of the Cerbo or App, it's just one more method of control. My main goal is to achieve the same functionality as the big Blue Sea switches, but in a smaller form factor and in a much more flexible location (e.g. my main control panel, or dash, or both). My garage area might not always be easily accessible.I didn't want to dig into that on the water-heater thread, but maybe re-post your big Victron drawing in a separate thread for discussion. If you have a Cerbo GX but are planning to also implement push-button switches, that's a bit of a shame when you've got such a powerful tool available.
I don't think I'll need to draw more than 100a from CCP2 to keep our batteries topped up (based on how often we typically drive, plug into shore power overnight, solar, and daily current usage).Same with running two DC-DC units to overcome Victron's lack of a high-powered solution: just run a single inverter for about the same price as one Orion and get the flexibility to charge as high as your planned MultiPlus (which will max at 70A @ 24VDC or ~1.8kW rate) /while/ using excess energy to power the rest of the system while charging the batteries.
