161 - 174 of 174 Posts
I posted somewhere else (or didn't click "enter") about issues that might contribute to noises regarding the drivetrain.
In regard to Ben's thought about driveline alignment:
If some motor or tranny mount is not installed tightly or is off-kilter, or if the whole assembly is a little off center, it could easily result in excess vibration. Especially at sympathetic harmonics. And maybe certain RPMs cause more vibration and components are too close together and "clack" as they touch, leading some people to think they have a TC or tranny issue when they don't. Or it could be a loose or misaligned front suspension component. In the past with some other vehicles, I've found rocks that found their way up onto the A-arm and were rattling around (yay! it's not a broken bolt!)
Looking at how sloppy the body panels and doors are assembled/installed in Transits, I would suspect the driveline components are also installed haphazardly. There will be great variation from van to van. Close inspection, and perhaps sticking a GoPro under the van to film the driveline motion while driving, might solve a lot of these droning, grinding, and rattling issues for people.
2015 148" LR 3.7
I agree wholeheartedly with you Surly Bill. I have gained a lot of insight from reading the discussions here. Many of them did not apply to my particular issues and every van is a little different.
I was lucky enough to be plagued with all of the common problems the 2015 models share. Particularly the shudder from the torque converter, guibo humming, the droning and the booming. It would be impossible to duplicate the repair work I have had done to my Transit on another Transit and expect the same exact results. My take-away and advice I have gleaned from my saga (to the non 2020 owners of course) is if you have the 65-70 highway shudder and rpm surging and it bothers you, then replace the torque converter with a rebuilt one. I bought my van used with 95k on it. Who knows how long the converter had been slipping before I got it? I had my mechanic pull the tranny and he said it was like new inside. So, I will venture to say that my shuddering torque converter was not causing damage to the transmission. I cannot completely back that claim up because I don’t know how long torque converter was bad. Maybe I got lucky with my driveline noise going away after all the tranny work. I definitely hit the jackpot with my exhaust fix.
My Transit is so much quieter and it is really a pleasure to drive now that I can hear my wife nagging me.
2020 MR 148, Ecoboost, Beluga white, more to come.
Update to drone noise:
I just got my new tire and wheel package installed on Friday. The drone is there but now it's at 80-88 mph (GPS calculated). That's not bad considering I very rarely drive at those speeds. My speedo is off by 12.8% now so 63=71;that's my default cruise.
Anywho, I was reading in other forums about driveline drone and a few other models of vehicles have exhibited this issue. There were a couple that had a harmonic generated in the leaf spring by a combination of road speed and exhaust tone. I don't think this is the case with the Transit as I tested the drone on stock tires with a payload of 3700 pounds. Still there and still at the same speed range. Also, our drone has nothing to do with engine speed/tone and everything to do with tire speed.
I'm going to investigate adding an aftermarket pinion nose dampener to see if that solves the issue.
134069
Just about any car coming from an assembly line or dealer shop can have driveline alignment issues as they are not going to take the time to do anything beyond the tech manual. To get any better you would need to go to a reputable driveline shop that specializes in this type of adjustment.
Would love to hear if the pinion made a difference.
I SOLD mine before I got screwed. I can live with the "turd fix", and the water literally pouring into the electrical wires at the first drop of rainfall (blood is boiling) but when I heard the droning I tapped out! Someone else's problem now.
2018 HR ext
  • 148"
  • 3.7 v6
  • Rear drive ratio (idk sorry)
  • 80-90 km/h only in 5th gear (6th gear either was very quiet droning or maybe went away)
2020 with 450 miles on it
148"
3.5L ecoboost
3.73 Limited Slip
Drone noise starts at ~74mph and runs up to 85...maybe past that....haven't been there though. Maybe it's a good thing...keep me under 74mph. Nahh, that can't be a good thing.
unkie
2020 AWD w/ 800 miles
High roof
148”
3.5L EcoBoost
3.73 Limited slip
Factory vinyl floor with the padding
No drone at all
148"
3.5L ecoboost
3.73 Limited Slip
unkie
which transmission?
what is rpm at those speeds.
Its more than likely the exhaust, no body seems to believe that but it's easily proven and easily fixed!!
Good Luck!
which transmission?
Good Luck!
All 2020s have the 10speed as I understand it. Mine does.
Does not seem to be rpm dependent since I've tried 10th, 9th and 8th gears at a fixed 80mph with no impact on the drone sound frequency or volume.
Exhaust - I'm going to mess with that if I can determine what to try, since the drone volume is to some extent a function of throttle position. On the theory that more throttle = more exahaust noise (though I don't hear exhaust noise inside the van). Though the torque on the diff is also a function of throttle position.
We already plastered every square inch of the cargo area panels on the sides, roof and floor in between the ribs with duramat. Quiets the general van noise some (air, tires, etc) but didn't affect the drone much if at all. Upholstered paneling will go up next.
I've tried to attach a photo of the exhaust tip to this...we'll see if that works. Outlet is out within an inch of the outside of the rear quarter panel. Not yet sure what I'd do to this to vart ut...other than add a few inches so I can clip pedestrians and hedgerows if I don't get them first with the side mirror. :)
I'll mess with it more on a road trip tomorrow and report back....see if I can be more specific.
unkie
which transmission?
Good Luck!
I think its the exhaust too but can you show how its easily fixed. I haven't seen that posted yet? I have my drone when i let off the gas from 60mph all the way down to 40mph and from about 1800 rpm to 1300 rpm
Edit - only in 6th gear. If i manual shift into 5th it pushes the rpms higher and I dont hear it as I decelerate.
Easily fixed by having your favorite exhaust guy turn the tailpipe 45 degrees and stick it out in the slip stream a bit.This is all basic car guy stuff, but i think most the people buying these and fitting them out shouldn't own tools, much less diagnose driveline issues.
A number of my wizards have conferred and concurred with me that the drone in my Transit is not exhaust since it is not a function of the engine rpm, and since the noise matches their experience for differential ring and pinion. Yes, such noises are clearly exhaust for some owners. Just doesn't fit here.
My noise is loudest at steady-state 79mph. And it's louddddd ! Slightly less noise under full throttle at that speed, and slightly less noise at zero throttle at that speed. No noise at 72 regardless of throttle position or engine rpm, and back to no noise at around 90...I didn't check engine speed or throttle position there, 'cause I was busy. But I'm not drivin' it at 90 so it doesn't really matter that it's quiet at 90. :) I've got other stuff to drive at 90+
I've tried a range of engine rpm and find the noise is unaffected by that.
I'll drive it for a while to see if it changes as the ring and pinion wear a little from new (still only 600 miles on it). Maybe tow something heavy for a ways to add more load on the gears. But give it back to Ford to correct it? Maybe, but suppose they make it worse....
thanks all for continuing to kick this around with me! I need to go back through the forum to reread on experiences others have had in getting Ford to pursue this.
unkiemotorhead
awful head splitting drone at 60+ mph. wasn't there last week, there this week.
no idea how it could've came out of the blue like it did.
defiantly sounds like it's coming from the rear axle but it sounds like wind howl, but I don't suspect it is.
2016
extended high roof,
eco boost 3.5
170k
tranny replaced before purchace
rubber guibo
I saw some damage underneath that looks like the flex coupling may have failed prior to purchace
I replaced the diff. fluid 2 days ago, no effect.
