I'm planning for flooring, probably a modest 1/2 inch of plywood. (No, can't do a fancy raised floor, or more layers of insulation, since I'm in a MR, and can't afford the space.) 3/4 inch would give better bite for screwing into, but, at a cost of more weight and another 1/4 inch of height.
So, what gets done at the side door step well, and rear door step cover? My floor already has the factory vinyl floor cover, which goes under the step well and step cover, so, Ford left 1/4 inch, or whatever, for that clearance.
It seems like I've seen pics where the step well sat over a fairly thick floor, but, I'm not sure exactly how that was achieved. Now, with a floor of only 1/2 inch, I think I could possibly cut a piece of the plywood to put on the step -- under the step well plastic -- probably with part of its edge showing. That kind of adjustment would then assume that the factory floor cover, or something of equal thickness, would continue to be used over the plywood.
I have not yet had the rear step cover off, to see what's under there.
Thanks
Thanks
