1 - 20 of 22 Posts
Hi all,
I thought some may be interested in these cargo van dimensions. These were taken from a 2017 Transit High Ex.
The original is large architectural size D which will print on a plotter. Otherwise just blow up the pdf on screen.
Click the link below.
Very interested in the PDF, but also don't have enough posts!
Awesome! I am in the research/design phase for my build and have not had much luck finding an extended, high roof locally (for purchase or taking measurements!), so your post will be very helpful. Thanks!
This is great, exactly what I was looking for. Unfortunately I have the same problem here, not enough posts to do anything and can't access the FB link.
Discussion Starter #14
Thanks for all of the dimensional info! Quick question. I’ve seen the interior height of the high roof stated at 81.5” several times. Is that from the floor low points to the bottom of the ceiling? If so, what is the distance from the top of the floor ribs to the bottom of the roof structure? That distance seems more meaningful from a design standpoint. Thanks.
Steve
1 - 20 of 22 Posts
