Guys,
I need better traction, for gravel hills. Winter will have dedicated winter studded tires, so this is just for summer months with loses gravel and sand.
I would like to just change the rear tires, like people used to do on rwd vehicles for the last 100 years..
If I put on 245/70/R16 Duratracs, I am sure they would fit. But they would be slightly different rpm than the front tires. Does the stability control get wonky over this?
I really don't want to replace the front tires, I like smoother front tires. And I can use my removed rear Hancooks for replacement fronts when the first set wears out.
If you have an option for an exact size 235/65/R16 in something aggressive with good deep lugs please let me know.
If it is load E I am happy, I don't load my vehicles up to he extent of some others. Most of the time I will be driving around with 500 lbs in it. I bought this vehicle for length, to fit window covering boxes in it, since this is an install vehicle for blinds.
I did my last four years in a F150 with a 6.5 foot box, it worked, but it certainly got old not having the length. But i had 4x4. I surprised how easily I spun out on gravel slops with this van, although I did find my tire pressure just too damm high.
