What's killing the battery is the LED lights in the cargo area...The system is still running even after the lights goes out...The best and fastest way to make sure your battery isn't dead over night is to pull the fuse that's in Location #F32...its a #10 fuse..which is located under the steering just to the right..you can located this locations by using the owers Manuel..this will sure that your van battry will not die again..I would still my own lighting system in the cargo area and avoid using these lights due to a defect in the computer system that allow the drain on the battery even after the lights goes out...I hope this helps everyone solve their dead battery issues...So Pull that fuse and leave it out. 05/05/2020expand...
