DC power cable for Starlink mini?
3K views 27 replies 6 participants last post by  ZillaG
I have this one: https://www.amazon.com/dp/B0DJQ7HY56?ref=ppx_yo2ov_dt_b_fed_asin_title I don't have my mounted, I just throw it in the windshield and it works fine. I put some velcro on the back and on the dash to hold it in place. I do have a pole mount on my rear ladder in case it's snowing. This one works fine and has all three connection types, 12V, USB-C, and the normal barrel plug to use with the ac wall plug. This cable feels very high quality and is not expensive.
Personally I'd stay away from the "cable with 3 adapters at the end" until I see one which actually provides some tech specs on how they work.
I've tested and used all three connectors on multiple trips https://www.amazon.com/dp/B0DJQ7HY56?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
1. I mainly use the 12V cigarette lighter (on the transit dashboard) while we are driving (with the starlink on the dash).
2. When I'm camping and it's not snowing I put the unit in the dash, and I use a USB-C 100W PD coming from the house battery.
3. And when it's snowing I use a direct 12V that comes from my house battery (a different cigarette lighter port), and mount it on a pole I have on my van outside so it can melt the snow.
That said, with the particular unit I linked above they all work fine YMMV. The specs are in the description, and the cable itself appears to be higher quality than the 12V 100 footer that ships with mini itself. Just my experience with the 3 in 1 I bought, it's been fine.
