1 - 9 of 9 Posts
I saw a post about adding a relay for daytime running lights along with a software mod.
I have searched for it but can't find, if you know where its at please send a link. Thanks
Pretty sure DRL are both in the menu and in ForScan...
Here's a thread where they are added via Forscan... it's your headlights in the off position, but running at 70% brightness when the transmission is not in Park.
There are also, apparently, hardware mods to get dedicated DRL.
That is not in the menu on my 20.
I wonder if that's a software version thing. It's there on my 2020. If you haven't fired up Forscan, it's pretty easy for this type of stuff. (y)
FWIW,
I replaced my turn signals with LED Switchback bulbs. Turn signals are now white running lights until turn signal is activated, then it is a flashing amber. Back to white running lights when done. :cool:
Semper Fi
Driving today - on a break at the moment - so thought I'd see if you've got the same menu I do:
Settings (press three-line button)
Vehicle Settings (OK)
Lighting (OK)
Daytime Running Lights (OK to toggle)
Just in case it's in there but hasn't poked it's head up. :)
1 - 9 of 9 Posts
