Okay, maybe less snarky reply, but here is what I did because,
1. I wanted the cord to be useable from multiple power sources, so not wired directly to the fuse block
2. The fridge is already fused, so wanted to be able to connect to a variety of 12V or 24V DC sources
3. I've read Anderson power connectors are more electrically efficient than a cigarette plug/receptacle ... at least they're more reliable staying connected
4. I can put an Anderson power connector on the cig plug end if I really wanted, then could plug into a car
But my snarky implication that if you don't know how DC electricity works, then you shouldn't be cutting and splicing wires stands. A refrigerator will not run backwards when plugged in that way ... well, it may get hot (and emit magic smoke) instead of cold, but that will not be long lasting.
