I purchased 2 identical units from Cruise n Comfort, but since these have DUAL Fan Condensers, they cool at 8,000 BTU, so 2 are not needed for the camper van, as two of these Cruise-n-Comfort units will be too cold.
You can email me at: [email protected] or call or text me on my cell at: 904-887-9595 for any additional questions or help.
BRAND NEW. IN THE BOXES, NEVER OPENED. No Wait. Delivered right away. Or we can meet in person.
COST: $6095. SELLING for $1,200 OFF for: $4,895
INCLUDED:
HD12L
The Cruise N Comfort HD Series 12 Volt split system air conditioners are built with 300 Series Stainless Steel components, making them perfect for use in harsh environments.
These 12 Volt Air Conditioners are extremely efficient because they operate directly from batteries. A large external remote DUAL condenser mounts to the outside of the area to be cooled and the unit is fitted with R 134a automotive style service ports to make the initial charging and future servicing easy.
This Cruise-n-Comfort HD Series Systems are a great alternative to retro fitting engine mounted compressors.
The optional ducting unit and the INCLUDED $299 DIGITAL Thermostat make it a great no-idle solution for Vans and Campers.
Cruise-n-Comfort products are hand assembled and delivered factory-direct from the U.S. factory.
*** This will need to be professionally installed and charged with R134a Refrigerant
Specifications:
HD-12L
Cool only
BTU: 8,000 (Extra Powerful because of DUAL PARALLEL FAN CONDENSER)
Input Voltage: 12 VDC
Current Draw:
30-46 amps @ 12 VDC
Blower Duct Size: 4"
Evaporator Inside Size: L 22" x W 12" x H 10,5"
Evaporator Weight approx. 69 lbs
Outside Size: L 4 1/2" x W 20" x H 14"
DUAL CONDENSER Dimensions:
Condenser core size: 14" x 25"
Overall condenser size: 14-1/2" tall x 27" wide
Overall thickness: 3-1/8"
Fan CFM (per fan): 950 CFM
Total CFM: 1900 CFM (both fans mounted on condenser w/ shroud)
Amps: NOMINAL 12.5 amp draw
MORE INFO:
Sharing the same construction materials, this MES Marine Series units the Cruise N Comfort HD Series 12 Volt split system air conditioners are built with 300 Series Stainless Steel components and hardware making them perfect for use in harsh environments and are built to last.
These 12 Volt Air Conditioners are extremely efficient because they operate directly from batteries and utilize Sequential Compressor Technology to reduce current draw from the compressor and the blower motor at times when max cooling is not required. A large external remote condenser mounts to the outside of the area to be cooled and the unit is fitted with R 134a automotive style service ports to make the initial charge and future servicing easy.
The HD Series Systems are a great alternative to retro fitting engine mounted compressors or adding additional cooling to anemic factory air conditioning.
The included $299 Digital thermostat makes it a great no-idle solution for vans, semi trucks, or small Rv’s. Why spend thousands more when this Cruise n Comfort A/C product is built from the highest grade components and hand assembled in the USA.
This picture shows only One Fan, but the Unit comes with DUAL Condenser Fans, which makes it go from a 7,000 BTU to an 8,000 BTU. (See 2nd picture)
- UPGRADED SYSTEM.
- CAB HVAC,
- EVAPORATOR
- DUAL FAN CONDENSER. (Upgraded to Dual fans which provides 8,000 BTU)
- COMPRESSOR
- SLEEPER HVAC SYSTEM (Complete)
- DIGITAL THERMOSTAT (Upgraded) CNC Digital Thermostat DT-03
- Great for Vans, Campers, Semi's, Limo's, and Construction Equipment
INCLUDED:
- HD 12L: 8,000 BDU, True 12 VDC Mini Split System, with 7 feet of condenser houses already crimped. COST: $5495
- Optional Digital Thermostat with 3 speed Blower, with Auto setting: COST: $299Product Description
- The DT-03 is a multi speed digital thermostat is specially designed to work with the HD Series units. The special software inside allows for your MES/ HD unit to benefit from the power saving technology. The unit has special software so that the units blowers can vary themselves in speed and air flow resulting in lower blower and compressor speed to reduce power consumption. If you still have questions how this will benefit you, please see the DT-03 Online Manual
- This unit has been upgraded to the DUAL FAN PARALLEL CONDENSER. HD/VES Series Air Conditioners. 14.5"tall/long x 27" wide: COST: $299.99
- TOTAL: $6,095. Selling everything, brand new, unopened, for: $4,895. ($1,200 off a brand new, never used never opened system.
- I am selling this system as I bought 2 identical systems and only one was needed, as they are so powerful with the Dual Condensers at 8,000 BTU, it freezes a camper.
HD12L
Specifications:
HD-12L
Cool only
Current Draw:
30-46 amps @ 12 VDC
MORE INFO:
