Wife and I are planning on picking up a High Roof extended body Transit that we are going to convert. We are more than likely going to pick something up off a lot as there are not many things we must have that would push us to order.
The most difficult to find option for us is the Passenger side glass in the sliding door. Not too many of these around in the cargo vans on lots. We also must have the tow setup. We will occasionally tow our Jeep with the transit.
We would like diesel almost entirely for adding the option of adding a diesel space and water heater like an Webasto unit. This will cost a lot but seems like it would add a lot of comfort. Open to input.
What I could REALLY use input on is 250 vs 350 and even dual rear wheel options. We are building out a camper van that will be used a lot for short trips but will hopefully seem some extended trips at some point. We have full timed in a larger RV before.
We are planning on solar, decent batter capacity and inverter. We will have a enclosed shower at some point and as much water capacity as we can get away with.
I'm not really sure how much this is all going to weigh. I am thinking of going with a 350 just to be sure. Not sure about the dual rear wheels? I would rather avoid the dual setup if I can.
Thoughts?
Thoughts?
