I've gathered so much from others on the forum that this is to share whatever I learn when I get to whatever I get to.
I'm starting out with a 2016 T150 148MR that is from an RV/used car place that got it from a Budget Rentacar bankruptcy auction with 60,000 miles. It's in quite good shape and one of the things that drew me to it was the proof that it had service every 3,000 miles. On the cargo wall behind the driver seat was a field of stickers, with one for each service. Also came with a new set of tires and the Ford cargo liner interior. Pretty basic T150 otherwise:
Anybody need a WeatherGuard wall in good shape? Removing it was wonderful, as it gave me over 2" of seat travel and is one less thing to rattle.
Put in a ScanTool2 and found I had to replace 3 ignition coils to clear recurring fault codes (P0300, P0303, P0304) but those may've been caused by the dealer cleaning the engine. The biggest problem otherwise is that the aft left door is slightly sprung and dented from people closing the wrong door first. It's also occasionally generated a P1450 code, so I'll need to eventually pull the valve and probably replace that. (<$20) Impressed that this big of a vehicle so far has been getting 18-19 mpg overall.
Out of curiosity I downloaded a sound meter app to my phone (Samsung S10) and took some baseline measurements. Highly doubt that these are very accurate as far as calibration, but as I make changes, I'll be using the same phone and app, meaning that any changes should have good relative value. Although the following data has the problem of different measuring techniques with different devices, I'm an engineer so love to have data. (iPad sketch) The black are my values and the green & red those of member Travlin, which I found in an older post he made:
Goal for the van is to be an enclosed pick-up that I can carry tubs of tools to go work on an old sailboat, haul the occasional motorcycle, haul a couple kayaks, and occasionally sleep in. For now I have a hammock to stretch out in and that seems to work well. Am planning to do some insulation without spending too much or going too crazy. Eventually will have some type of walls, ceiling, and bed but being a 150 want to keep the weight gain as minimal as possible.
Tomorrow I'l start putting in this sound deadener, which was a lot less expensive than Noico, Kilmat, and most other brands:
https://www.amazon.com/gp/product/B07ZKLKHN5/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
Lifted the rear corners of the Ford floor mat and found that the fabric is soaked so getting that out and putting in a level floor is a priority too.
Will post more when more happens.
