1 - 4 of 4 Posts
These are out of a 2018 15 passenger T350HD XLT with 13,000 miles. They are charcoal cloth with armrest and recline (3"-4") function and are in like new condition as far as I know. This is the 2 single seats, third row double and pair of fourth row doubles. They do include the bases. Tracks and mounting bolts are not included.
$600 for all seats and must be picked up in Rockmart GA 30153. I am located about 60 miles North West of Atlanta.
The pics included are not the actual seats (in storage) but should be an accurate representation.
Discussion Starter #2
The 36” wide double with an arm rest has been sold.
Remaining seats are $100 per single and $200 per double or $400 for all.
Remember you can get the floor mounting brackets through Ford using the part number for the single seat quick release floor mounting bracket. The part number is KK4Z 9961756-C and you need 2 of these brackets when you are working with the single or 2 passenger 31" or 36" seat. It takes 3 brackets when using it for the 54" or 62" 3 passenger seat.
The floor mounting brackets will come with the bolts to install in a passenger van based on the threaded bolts in the floor. To install in a cargo van, you need to use Grade 8 bolts (about 1/2" longer than the bolts furnished with the bracket) with lock washers and locking nuts.
If installing behind the driver's seat, be sure to lower the fuel tank before installation as drilling in this area may cause puncture of the fuel tank.
1 - 4 of 4 Posts
