I cannot think of any reason why he could not do that. He could also run a short wire to a 60 amp fuse, leaving the existing fuse intact. Or, he could just upsize the wire and get the benefit of lower resistance.Could he not just swap out the 150A fuse for a 60A? I realize the 150A is there to allow someone to connnect up to 150A draw from the CCP but if he knows his system will only pull 60A then change the fuse and put the wire in for that.
Interesting, I just made a post about this yesterday. That 150 A goes no where, and the 60 A below it feeds the CCP.@Neff, what did you end up doing here out of interest for myself?
Ill be in same position, so appreciate your reply.
