21 - 37 of 37 Posts
Discussion starter · #21 ·
Future work - This mock-up will be the basic design of the shower box door. Marine cleats are to be used as coat/hat hooks.
This is how I communicate with Ed as to what we are imagining. I will do a Photoshop mock-up and Ed takes it from there and creates the reality.
Discussion starter · #24 · (Edited)
Stunning. What is the large box in front of the rear doors?
50 Gallon Fresh Water Tank. It is boxed over with wood and auto carpet so Lithionics External BMS can be mounted to front facing side of it and we can store stuff on top of it. Rear seating area and under seat storage is framed out in Black 8020 over it. Thank you for the compliment!
Discussion starter · #26 · (Edited)
2024 Ford Transit Touring Van "Ghost" Build Progress
Marine Vinyl upholstered panels in Classic "Riva Aquarama" colors to match ceiling panels have been fitted under "Happy Jac" Elevator Bed.
Teak & Holly Strip Deck Flooring fabricated for raised floor in front of rear seating/dining area.
Cruise N Comfort Air Conditioner ducting test fitted.
Rear seating/dining area woodwork being test fitted.
Discussion starter · #27 · (Edited)
2024 Ford Transit HD350 "Ghost" Touring Van Build Progress;
Cabinetry for Isotherm DR130 Marine Refrigerator is being fabricated from 3/4 Marine Plywood with African Sapele Mahogany veneer. This will be topped by Hickory and Mahogany Butcher Block countertop. Appliance garage will be above of countertop Breville Microwave. To the right side of the refrigerator will be a pull out pantry drawer.
Sample drawer front is being mocked up out of 3/4 Marine Plywood with African Sapele Mahogany veneer and framed with solid Mahogany edge pieces. The drawers themselves will be full height solid 5/8 mahogany that will be dovetailed together. Latch is Stainless Steel Marine cabinet latch.
We chose the Isotherm marine refrigerator because it runs on DC power and can handle being in constant motion and not always level.
You can also see the raised Teak & Holly step which will hinge up for storage underneath.
Discussion starter · #30 ·
2024 Ford Transit 350 HD AWD Dually "Ghost" Touring Van Build Progress;
Shower and Backsplash Tiles have all been grouted with Epoxy Grout.
Shower Box door frame has been fabricated, finished and installed.
Refrigerator cabinet has been fabricated and installed, Isotherm DR130 Drawer refrigerator installed.
"Happy Jac" elevator bed has been full trimmed with solid Mahogany (complete with Interstate Vans & Ghost logos laser engraved).
The ceiling panels under the "Happy Jac" elevator bed have been finished and Mahogany center strip with classic Marine Cabin Lights installed. To add further illumination LED strip lights installed full length along the Aqua racing stripes on each side.
I really think Eddie Trayner of Interstate Custom Vans https://interstatevans.com/ nailed the theme which was match the aesthetic of the 1962 Riva Aquarama which I consider the most beautiful boat ever made.
Discussion starter · #31 ·
Shower Box Door being fabricated from solid Mahogany strips on both sides of Marine Plywood core and trimmed in solid Mahogany. Porthole Mirrors on both sides.
Rear Equipment area cabinetry being test fitted.
Rear Equipment area countertops of Hickory Butcher Block and solid Mahogany trim being fabricated
Mahogany panel for Paneltronics Circuit Breaker panel and Garmin SERV touchscreen control panel being test fitted
Discussion starter · #32 ·
Galley Lower Cabinet fabricated and finished and installed.
Appliance Garage Countertop finished. This entailed Eddie Trayner inlaying a center strip of solid Mahogany into the Hickory Butcher Block top and then edging it with solid Mahogany as well.
Mahogany panel above the refrigerator cabinet/appliance garage has been fabricated, finished and installed. This will house the Paneltronics electrical panel and Garmin removable SERV touchscreen control panel.
Shower Box Door fabricated and finished.
Interstate Vans | Custom Van Builder
Discussion starter · #33 · (Edited)
Electronics Installed and wired in. Protective wood over the actual Hickory & Mahogany countertop while Eddie Trayner is working. Breville Microwave will go on countertop then above it a large Mahogany shelf for assorted appliances, etc.. and a smaller Mahogany shelf for charging various devices. We put in multiple outlets and they have USB ports built in. The Garmin SERV touchscreen is on a magnetic mount and is removable so you can control & monitor pretty much everything in the van from it. Very happy with the wood work as it really has the yacht interior vibe
The workmanship is outstanding.
I am very curious to learn more about that Garmin SERV system. Can you let us know what it is able to control?
Discussion starter · #35 ·
Discussion starter · #36 ·
Eddie Trayner is working on the Galley lower cabinet and countertop. That countertop will match the appliance garage countertop when done.
There will be a drop down table on the outside galley cabinet for cooking outdoors when the Van side door is open. Light switch panel, 110 volt and USB/12 volt outlets are being installed as well.
Discussion starter · #37 · (Edited)
Beginning of October
Lots going on this week;
Heating System fired up and working.
Paneltronics Electrical Panel wired up and working
Garmin SERV Touchscreen Control Panels wired in
Sound System up and running
Rear cabinetry finished and fitted. Air Conditioner, heating and Cabinet Ventilation Fans installed. USB, 12V, and 110 Outlets fitted
Appliance Garage LED Lighted Mahogany Shelves installed and working
Rear panel finished and fitted with Outdoor Shower and Water Tank Fill hardware, Rear Air Conditioner Extendable Vent, USB Outlet, 12V Outlet, 110V Outlet, Lighting Control Switches and Main Shutdown Switch.
Mahogany Upper Galley Cabinet Finished and Installed. Cabinet sides match the curve of the Happy Jac Bulkheads.
Rear Teak & Holly Raised Floor Storage Compartment Hatch cut in.
Front Bulkhead Hatch Frame & Door fabricated and finished and waiting to be installed.
21 - 37 of 37 Posts
