The + connection(s), typically red wires , for that stuff is probably ultimately connected to a post on the side of the seat or to the positive of the battery, which is under the seat (4 bolts to remove seat)
The - connection(s), typically black are either to something metal on the the van chassis somewhere or the negative terminal of the battery.
There may be a small gage wire(s) like the one from the solenoid (cylindrical silver thingie) the ties to a connector under the seat.
Basically trace all that stuff in the photo back to it's source and remove. First thing you should do before messing with any of that is disconnect the battery negative and put that cable where it can't touch any other metal. You will need to take the seat off to do that.
If you post photos of the wiring under the seat while you are there it will help folks guide you. Also take a shot of any wiring to the seat. That will also help.
Something that you can easily do yourself ...assuming the EE did it right, there was no need to "splice in" they should just be additional connections.
If you elect to have someone do the work, IMO it shouldn't take anymore than an hour ...and that is generous.
I'd suggest you do it yourself, cuz it's not difficult and a good way to learn about the battery connections in your van.
FWIW, it looks like what you have is an inverter that was run of a now removed auxiliary battery that was connected/isolated from the van's battery by the solenoid that I mentioned above. If you were to clean up the wiring and add a deep cycle battery with the same chemistry as the one other the seat (either AGM or sealed lead acid) you would have some AC power in the van if that is of any use to you. What are your plans for the van Stan?
