1 - 9 of 9 Posts
I ordered my van with the bidirectional remote start. Now that it's cold I've been using it. It works fine but I can't figure out why it's considered 'bidirectional'. It's just a little square fob with a single rectangular button. When I google 'ford bidirectional remote start' it comes up with a very different looking remote from that I have and states it works 1000' away. I have to very close to even get it to work. Did I receive the correct thing?
Discussion Starter · #2 ·
One other question.
When the van is running and I go to get in it the engine shuts off when I open the driver door. Is there a way to get it to keep running so I can load the car without the heat shutting off?
Discussion Starter · #4 ·
Wanted to add that there is a big antennae attached to the inside of the windshield. Did the dealer install this? Shouldn't a factory system have hidden wiring?
on ours if you hold down the remote start button for 3 seconds while its running it will honk and you can remove the key it will stay running. The bidirectional has a led in it that blinks green when the remote start is active letting you know it's running. The antenna they installed was not big at all maybe 4''
Discussion Starter · #8 ·
The remote I have is a small square with one single button. There is no green light, just a red one. It doesn't beep or make any noise at all there's no way to know if the engine started without listening for the van to honk.
Mine fell down from behind the rear view mirror on recent trip. Startled us a bit. Found although it is a factory option, it is installed at the dealership. They forgot to remove the plastic from the 2 sided sticky tape and attached it with another piece of tape. Simple fix and back where it is supposed to be.
Semper Fi
1 - 9 of 9 Posts
