Unfortunately I don’t have a picture. I had the system installed at a professional shop in Las Vegas, NV so when I picked it up, it was all buttoned up and back to looking OEM. Sorry!
We installed 2 small amps under/in the dash sorta to the right and above the glove box. Custom 10" sub box, focal 6.5 components and 6.5 coaxial and it's amazing!
On previous sprinter van, had my large older kicker 4 channel amp under pass seat simply screwed down to a 3/4" plywood scrap cut to fit snug between seats under floor, could do also on my 2019 t 250 base model.
When talking amps , it's like talking tires----- many different sizes. Many newer versions are much smaller now. Always good to have some air space for cooling.
Not sure how 2020 models compare to 2019 back, which have battery under seat, Some amps could fit there, but less room.
All depends on the amps! I have some Zapco 6 channel and Mosconi 5 channel amps that are way too big. I plan on mounting them in the rear walls (hope I never fender bender these..)
Not sure if this is an option for your passenger van but I installed my amp and powered sub in the walls behind the driver's seat. I used the panels from DIYvan (Hein) to install a 4 channel amp and a Alpine Sub.
I have the same thing.. 2 batteries under drivers seat and heater under passenger seat.. One option if you keep the first row of the back seats is to mount the upside down under the rear seats. or you can also be creative depending on the Amp size. I'm using left overs from a SQ build (from a different vehicle) and wish not to spend more if I already have stuff laying around ;-).. Mine are huge so to maximize van space they are going vertically on the walls hidden behind a cabinet under the bed storage space.
10 inch sub. 4 channel amp and Jvc DVD head unit all mounted behind passenger seat and Alpine head unit in the dash
Which ever head unit unit I turn on will trigger the amp to turn on , and so front and rear stereos share the subwoofer
Related Threads
Ford Transit USA Forum
422.4K posts
44.1K members
Since 2012
