My head spins with all the combinations possible for towing:
http://www.ford.com/resources/ford/general/pdf/towingguides/Prelim15FLRVTT_Transit_Apr22.pdf
While I've heard historically that diesel is always the best choice for towing, the Ecoboost 3.5L confuses the issue. This is particularly true when you are looking for an option that supports both heavy duty trailer hauling (for which diesel is supposed to be better) and around town errand running (for which gas is suppose to be better, particularly if you live in a cold climate like a Colorado ski area).
My situation is that I want a Van (not a Wagon), that I can put my recreational toys in (kites, kiteboards, surfboards, skiis, bicycles, etc.) and use around town and short trips and still use to haul a travel trailer across country. I expect the mix to be about 50/50.
The fact that the Ecoboost 3.5L (EB) in the T150, Medium Wheel Base, Low Roof configuration starts at 5600 and can go to 7000 lbs towing versus the Diesel 3.2L that starts at 4700 and jumps to 7500 lbs has me really confused. Why would the diesel start with lower tow rating (3.31 axle, 11,200 EB vs 10,600lb GCWR) suddenly have a greater towing capacity than the EB when configured comparably the same (3.73 axle, 13,000 EB vs 13,500lb CGWR)?
And on the GCWR rating, do they just put in stiffer springs until you reach the 13,000 plateau at which point it is dual rear wheels?
It seems like for my desired use of part time towing a 4500 lb fully loaded trailer with probably another 1000lb in the van, that I would be best off with the Ecoboost 3.5L with an 3.73 axle and 11,200 or 12,600lb GCWR.
What say you guys with towing experience?
