John, I had a large portion of my van's modified metal floor coated 10 years ago with Line X (or Rhino, can't recall and I'm not home to look it up), and it's held up great. I use my van primarily for traveling and/or camping so it doesn't get the abuse yours will. I occasionally carry stuff on the floor but mostly it's just to walk on.Has anyone here actually had the floor of his cargo van sprayed with Line-X or a similar brand of bed liner?
...cut.....
Suggestions and opinions are sought, especially from those with Line-X.
Thanks in advance,
John
I'm a carpenter and have a similar plan.Has anyone here actually had the floor of his cargo van sprayed with Line-X or a similar brand of bed liner?
I'll be ordering a Transit in a few months and considering the following order of events:
1 - Take delivery of van
2 - Temporarily remove factory-ordered cargo wall protectors
3 - Install steel bulkhead/partition now to protect cabin from overspray
4 - Have Line-X sprayed on floor, wheel wells and perhaps 12" up the sides.
5 - Re-install the cargo wall protectors
6 - Install steel shelving units
I'm an electrician and the interior will be subject to some but not serious abuse. I think this approach will give me an attractive and durable floor for an everyday work truck.
Thanks in advance,
John
I absolutely have, but my carpentry tools are large, heavy, and usually are stored in rolling toolboxes or soft bags that currently in my Sprinter occupy the area directly behind my partition. The idea of a more substantial cabinet is to move the items into a vertical arrangement, rather than across the floor. I've found the folding shelves to not be large or versatile enough.Have you considered a delivery truck style folding shelf package? Might be easier than taking the shelf unit out.
Anyone see an issue with dropping the ply on silicone or construction adhesive? I sure ain't going to drill through the floor.
I never thought of fabbing the entire floor out of the van. That's a good idea. I have an extended body though. That's approximately 14'x65" to muscle into the van with wet adhesive all over the floor. Could potentially save a trip back to Line-X though. I'm expecting about 1000 bucks to Line-X the cargo area, and maybe another 500-750 to coat the ply once it's installed.The BEMM manual states to use 9mm (~3/8") Marine grade plywood for flooring. It also states that the wood floor should be ONE piece.. Marine Ply is generally considered stronger than the other types, and will give you a significant weight savings. When edge joined correctly, it is EXTREMELY strong.
I plan on using the 3/8 marine fir plywood. I'm going to make scarf joints (YouTube) to join all the plywood edges in order to make one large single piece of plywood floor. I've used them before on boat projects. These scarf joints are EXTREMELY strong when joined using the Wood Epoxy Saturation Technique, or even Sikaflex marine adhesive on the scarfs. Then I will use the floor liner supplied to trace the correct lines and locate the hole location on to he 'one piece' plywood floor. Once it is cut out, and drilled, and edges sanded, I will use a few coats of WEST SYSTEM epoxy to totally encapsulate all sides of the plywood sheet, including the edges. It will be bedded down using 3M Adhesive (probably NOT 3M 5200) or Sikaflex, and secured using the factory holes.
I REALLY LIKE your idea about taking every thing out of the van, and putting the 'bed liner' product on the floor and 1 foot up the walls! I'll probably do it as well.
From your other post, it appears you have a Transit Connect? FYI there is a sub-forum dedicated to the Transit Connect:Anyone went with the Line-X route? How do you like it so far? I'm thinking of doing the same thing.
