1 - 5 of 5 Posts
High roof transit seems like it will be the ideal shell for me and my business. I need a high roof with plenty of windows to use as my mobile office/ work van, but it also will be used as a basic traveling van for short 3-5 day mini-vacations. I will be putting in a VERY basic living floorplan, as I have seen alot of B motorhomes that seem to just have too much "stuff". The new sprinter is also perfect shell also, but service availability is a crap shoot for my situation.
· Premium Member
You hit the nail on the head, and that is the same reason I'm looking at the same model (the 22 footer, high roof) for my needs as well.
What I plan to do is have one upfitted through Sportsmobile with a Danhard air conditioning unit. This way, there isn't the large unit on the roof which lowers the height of the rig, and I could use a roof rack on top for additional storage (RotoPax containers come to mind for long boondocking trips.)
From what I can tell, there are going to be multiple cool factory options available as far as windows that open on the sides of the van. I look forward to seeing a transit with those windows installed. Being somewhat of a minimalist, I am going to try to initially hold off on the roof air conditioning. Just the extra noise, the need to close up the inside, and the fact that I am in northern Illinois makes me hope it can be something to do without. I will be insulating walls and floors, and also will be making screens for passenger side sliding door. Plus the max air ceiling vent/fan is pretty capable of moving air. I do have a local RV dealer that I am hoping will help with my shorepower install, ceiling vent, and 12 volt inverter setup. I have spent alot of time on the Sportsmobile website also....just seems they are touting full feature set-ups, rather than a more simple design.
I couldn't agree more on what seems to be Conversion builders trying to see how much stuff you can cram into a van so the end product is claustrophobic and impossible to turn around in. Still can't see the need for full-height cabinets or that silly, full bath right in the middle of the floor plan. We plan to push the bath all the way to the rear and make a wet/utility/toilet area that can be sectioned off for efficiency of heating/cooling/exhaust.
I couldn't agree more on what seems to be Conversion builders trying to see how much stuff you can cram into a van...Still can't see the need for full-height cabinets or...
Greetings,
Yea i know this is an older thread...but i'm a new guy on the block catching up on good reading ;)
My wife and i have a DIY conversion that we designed a bath _closet_ that can be seen with a detailed write up at our build thread. If you follow _this link_ and scroll down about half way you will come across some pictures. Basically it is a shoulder height closet that is about 18" deep on the floor and ~30" wide on the wall. It houses our potty, shower, and personal hygiene items. when not in use it is simply another couple of doors on a wall not taking up valuable space in the van.
Here are two shots (and what to look for on the page i linked to for the write up)...one closed
and the other open (in shower mode)...
Thom
1 - 5 of 5 Posts
