I have seen a number of posts about it, but nothing definitive.. Hoping we can shed some light on this for everyone's sake.
I would love to add all these features to my base cargo Transit, but I need to be sure before I hunt down the parts that it will work.
Can I swap just the steering wheel or the entire steering column to change this out, or do I also need to swap the dash module because of the necessary interface with the dash info system?
Would it be easier to just add CC and audio controls instead of all 3?
Who has a solid handle on the CANBUS control system? Would you be willing to share your experiences and or expertise?
Does the ECU need to be flashed to accomplish this task? If so is that a Ford factory thing or FORSCAN, and can it be done in a shop with software or by an individual?
If it's useful..
My setup is as follows, and I promise to be as helpful as possible to answer these questions and I will happily share my findings as I dive into this.
2018 Transit Cargo 3.7 HT-EL 35,000 and it's halfway outfitted to where it will be in a few months.
If it's useful..
- Phantom S9 Window Tints
- Max Fan
- Wall EZ Cool Insulation (Full)
- Complete Sound deadening
- Thinsulate wall panel insulation (Full)
- Fully Insulated Flooring build up (insulation, ply, vinyl)
- Fully insulated
- Professionally Installed Lonseal Laminate Flooring
- Coin-mat in Garage + 2’ Side Walls for Utility & Easy Cleaning
- Professionally Welded Aluminum Wall & Roof Framing
- L Track on the Walls
- Upholstered Paneling Wall & Roof System
- Central Control Unit for Power & Lighting
- Thetford 92306 White Toilet
- (8) Flush LED Lights O.C. (2-Zone Control)
- Versa Bed & Bench System
- Aluminum 42" Galley with 1 Door and 3 Finger Slam Drawers - (Silver)
- (2) Aluminum Overhead Cabinet for Non Factory Headliner (42” x 18”)
- 15" Ruvati stainless steel sink
- Passenger Swivel Seat
- Walnut Counter top (+Walnut Trim) (4’ x 8’) & Back-Splash
- Extendable 1’ Walnut Counter
- Goal Zero Yeti 1400 Lithium Battery System
- SS Pull -Down Faucet w/ 3 Function Spray Head (Regulated Stream, Spray, Pause
- Dometic CFX 65W 12v Cooler, Fridge Freezer
- CR Lawrence Passenger Slider Door Pop-Out T-Window
- (4) Open Country AT III ON-/OFF-ROAD ALL-TERRAIN TIRE
- SIZE: LT255/70R16
- FVC LOW PRO ROOF RACK - TRANSIT 148" HIGH ROOF EXTENDED
- Renogy Solar Panel
