41 - 60 of 127 Posts
i so thought i would actually have something to report by now, but with difficulty in getting product and back orders now in this weird time... it is the "get ready for winter" time of the year as well, cutting trees for next years wood etc.
anyway, finally got some time. started fabbing brackets for overhead shelf before i remove the headliner to insulate/sound deaden. seemed like a good idea, but now the Russian birch is sold out locally, so.....
View attachment 140829 View attachment 140830 View attachment 140831 View attachment 140832
and i finally got the roof rack installed. i toyed with the idea of buying the tube bender i wanted for ever and making my own rack, but decided i needed to pick my battles on this build and make some progress (might still buy a bender to make a ladder since nothing out there fills my desires). i went with a local company, Remora in Montreal. it went together really well and impressed with quality. so you canadians-check em out. now that i have the basic rack installed i can figure out my solar/maxxair placement and get my solar parts ordered
View attachment 140833 View attachment 140834
As you have had time to utilize your van with new roof rack, can you elaborate on the strength/durability (...i.e. do you think would it be strong enough, assuming you installed additional cross-members & platform, to support 2 people?) and comment on any road noise?
Discussion Starter · #42 ·
HA, i actually have not "utilized" van, i have 273km on it. since its winter here in quebec and its not my only vehicle, its in full build mode and hasnt left the shop in months. actually illegal for me to drive it technically since there is a "snow tire law" here, and its on stock tires still. tire shop is in my neighborhood though--so eventually ill get it over there for proper tires
so no comment on road noise since when i did drive it around it was empty cargo van. not my first modular rack though and see no issue with strength. i did pick up an addition cross member because it will help my plan
Discussion Starter · #43 ·
So almost 6 months to the day after i ordered my CR Laurence windows, i got the last of the 4. It has really been holding me up and i was getting pretty bitter about it. Anyway, last 2 windows i was waiting for were the 10x33 bunk window sliders. a lot of people like the 10x33 awning windows because they can be opened in the rain. all fine and dandy, but if you drive with a CRL awning window open you will soon regret it. So, i have awning windows in the big locations behind driver and side door for ventilation if its raining, and slider windows in the bunk for more ventilation while driving.
got busy and cut the holes and did my finish utilizing the factory bump outs for EAST/WEST bed set up with out buying Flares. wasnt really sure if my plan would work but quite pleased with the results and ended up at 75" wide (at the widest) tapered back to 73.5 in the back, which is pretty much standard RV bed size. and i was still able to insulate with thinsulate behind my panels and could maybe get it slightly wider
getting ready to cut the hole after a ton of careful measuring to make i finish according to my plan in my head, and finished the upholstery
146860
146861
window in and make a frame around it
146862
make a panel and upholster, did a lot of card board trial fits first
146863
then got busy making curtain for the window, which we make a lot of, and installing everything
146864
146865
146866
146867
and like i said, 75" side to side. now to finalize my bed plan--my head is full of to much stuff....
146868
Fantastic work! I'm thinking of doing the same layout for windows. If you kept any of your cardboard templates for your paneling I would be interested in purchasing them when you are done with them.
Reactions: coguzzi
Discussion Starter · #46 ·
Beautiful work!
What did you use under those last inset panels to bolt to?
seems i dont have a good photo of it, or its an industry secret--;). basically i built a frame with threaded inserts that is then upholstered and riveted/screwed/marine adhesived to the inner metal structure. thinsulate inserted, panel installed. my next time lapse video is almost done and shows it actually
That's what I thought, but I was hoping you could provide details of what you did so others (I) could copy it? What is the internal frame made of and did you use rivets, sheet metal screws, or adhesive (and if adhesive, which product)? And if you could even be more generous with your expert knowledge, the specific bolt used to mate to the threaded inserts? I'm not sure why you would upholster a frame that is completely covered, though, but maybe you were referring to some other application?
Again, it looks so good!
Discussion Starter · #48 ·
about the best pic i can find
146970
Discussion Starter · #50 ·
I get it, now! Threaded wood inserts. Thanks for that. Did you use 3M 5200 or something else for the wood strapping adhesive?
i used sika 291, equivalent to 4200, its what i had open. 5200 would also be fine, so would windshield adhesive--really anything that remains flexible. its more about making it more secure and not vibrate than it is "fixing it" there are brackets with screws and rivots in the internal metal structure as well. its glued in the corners and in a few spots along internal ribbing (not full length). definitely only want to use adhesive on internal structure and not to the exterior skin, it needs to shrink and contract with environmental changes and will ripple if glued to the skin (not to start a urethane debate here)
Discussion Starter · #53 ·
Another awesome video! What's the fabric that you use before applying the Duramax? Is that enough to create a thermal break from the van metal?
its 1/8" landau foam, its a closed cell foam specifically for vehicle applications. and yes, provides thermal break on top of cushioning and sound deadening
Discussion Starter · #55 ·
Thanks for the info! What type of glue do you use for the foam/fabric?
a high tack automotive upholstery contact cement, sometimes referred to as landau top adhesive
Discussion Starter · #56 ·
wiring wiring wiring......actually this one wasnt to bad since im taking the overland "everything you need and nothing you dont" approach (except for couple wife request as i said earlier). this one was a breeze compared to the last sprinter i did for the shop i used to work at.....geez....
Anyway, 30 amp shore power coming in along with an SAE connector for future solar suitcase needs if me or the next person wants it in addition to what on the roof. solar on the roof only works well if parked in the sun remember
148140
then just pulling wires/circuits, rinse and repeat. seems ive spent half my life wiring things
148141
and after the initial layout is done getting it all loomed up and into the cavities where it will play nicer with everything
148142
148143
and now i can finally move onto some finishes, i love it when things start to go back together. first up, the foam blobs as people call them. i reshaped it slightly and i filled in the irregularities, wrapped them in foam and tweed. held in with some high quality automotive velcro and tension fit
148144
148145
148146
and finally start upholstering my panels and doing final install---at least a couple, still have some things to build--like bed structure
148147
148148
2022 MR AWD Ordered 9/14/2021
Those panels look very nice finished. From your previous posts before they are covered, what is the panel to panel gap? Also do you have a standard corner radius on the panels so that two pieces come together nicely?
Discussion Starter · #58 ·
im using 1/8" foam plus fabric (maybe 1/16"). so my gap between 2 panels is 1/4" so it give me a little "squeeze" to make a tight fit. no radius on the wood for panel to panel fits (but the foam creates its own radius). but on panels that are just an opening i put a small radius on to make em more smooth
Discussion Starter · #60 ·
from organized chaos (actually got cleaned up and loomed after photo because im kind of OCD about wiring)
148799
to installed mobile command center
148800
148801
