1 - 1 of 1 Posts
Doing some repairs on a work truck for the place I work for, its a 2010 Transit Connect. Trans has been out 3 times, the last time to replace a bad part from the previous repair. I originally thought it was a bad wheel bearing but after some troubleshooting, I 'm pretty positive its the axle bearing. I pulled the passenger side axle to replace the bearing but it feels fine, so now I believe the bracket that holds is worn. Is this a common failure on the Transit?
It seems like the bearing is not held very tight by the bracket and there was noticeable slop when I grabbed it and moved it around. I'm returning the bearing on Tues and ordering the bracket.
1 - 1 of 1 Posts
