Today I took my Transit to the dealer I purchased it from to once again attempt to have my sliding door mechanism repaired.
I was due for an oil change so had that done, and decided to have the tires rotated since I hit 25,000 miles on the Hankooks.
I assume the oil and filter were done, but I was AGAIN told that my door is messed up and in need of repair, but that they could not do it and that I should search for a dealer that can.
I know that they DID rotate the tires and properly change the inflation to the correct front and rear PSI because on the drive home the TPMS light came on.
At home I checked and they were within 2 PSI of the door jam placard.
So for the first time ever I recalibrated.
What a joke!
At least the manual warns you to have a compressed air source available.
You have to bleed a lot of air out of each tire to recalibrate!
And the system is so insensitive to begin with that if you're down to 35 PSI from 49 it doesn't even warn you.
The TPMS system in my Sprinter was more sensitive and easy to recalibrate directly from the driver's seat.
I'm thinking about disabling mine.
Any tips?
What a joke!
Any tips?
