I've been reading old forum discussions on optimal insulation methods. I decided to put together a quasi-1D thermal analysis of the roof/ceiling to allow some sensitivity studies (e.g. XPS vs Thinsulate) and evaluation of where the major losses are (ribs vs bulk roof). The primary intent of this model wasn't quantitative determination for losses, but instead comparative evaluations.
The analysis is here.
On that page you'll see a description of the model, and a link to a google spreadsheet with the parameters (and basis) used to determine the resistance values. I wouldn't consider myself heavy on thermal analysis so any feedback or suggested improvements (or glaring errors) are welcome.
Tentative Conclusions:
XPS (1.5") on the ceiling doesn't provide a massive benefit over SM 600 (1.65") thinsulate (15% delta in loss).
25-30% of ceiling heat loss occurs via the ribs.
Notes: Bulk insulation is XPS or Thinsulate (between ribs). Over top of this is 5mm coroplast panels with the outward (cargo-space-facing) side covered in 1/8" neoprene. Model also allows for neoprene on backside (one case examined). Outside of the panels there are two lengths of L-track that run almost the full length of the cargo area. L-track includes a FR4 thermal break from the ribs. L-track helps retain the coroplast panels.
