Is anyone using magnets or different clips for holding the trim on a passenger conversion? The amount of force and prying needed to remove trim has lead to a lot of wasted time, broken trees, scratched paint, broken clip holders and I'm considering other options as I'd like to button up the inside for some test trips, but still be able to get back in those areas easily.
The first thing I'd like to do is replace the few clips that basically have the one-way prongs in them. These are found on a few clips on the a and b pillar. Maybe I'm doing it wrong, but I can't figure out the right way to release those clips. They are silver in color and have two prongs at the tip that lock into the medal. I'm considering replacing them with the standard brass clips that are used in many other places, but not sure yet if they are the right height.
The other issue are the various trees that are all through the trim. Some are easily removed, others take so much force that the metal can warp and the paint is scratched by the long metal tools . For these I was thinking about using the plastic trees on the end, but for the inner spots that are hard to reach use magnets or velcro.
All ideas welcome on how to make this easier.
