I put in a similar sized sliding window.i just cut through it all then used brutal tape on the inside to have a uniform thickness.i laid it out on the inside used a angle grinder with a cutting wheel from the inside making two short cuts on the top and one on each side,then went outside and traced the opening with a cardboard template ,put on masking tape to avoid scratching the paint and cut out with a jig saw
